ecm-1240 energy monitor
Hi, masters I have an ECM-1240 Brultech it sends binary packet each 2 seconds through serial rs232, its driving me crazy because i cant read it only garbage on VISA LabView (on the contrary when i program device to send ascii). Need to read each byte and traslate to decimal values to work with them.  I depend of your great help! please show me diagrams im not an expert. Thanks
Message 1 of 9
(5,084 Views)
Convert the string with the String to Byte Array function. Then you can use Index Array. Combine bytes with the Join Number function.
Hint: make your string more readable by right clicking on it and selecting hex display.
Message 2 of 9
(5,076 Views)
Thanks Sr. but trying to read voltaje in decimal i get wrong data, maybe the program is wrong?
Message 3 of 9
(5,064 Views)
Accepted by DiegoBonilla
Array indices are zero-based.  Your chart of bytes starts with 1.
Wire a 3 into the index array.  Drag its bottom border down by one spot.  Now you can get rid of the extra index array.  You've got index 3 and 4  (which correpsond to 4 and 5 on your chart.)
Message 4 of 9
(5,050 Views)
still doesnt work see.. i upload the packet format, thanks for help
Message 5 of 9
(5,031 Views)
You don't have the three header bytes present. It seems the data is constantly streaming so you are going to have to synchronize it. Read until the first three bytes are correct. Then read the remainder. After that, you should be synched and can read the entire packet which seems to be more than the 43 you are specifying.
Message 6 of 9
(5,003 Views)
thanks a lot Srs. grateful help. After synchronized serial input i habe been get volts and current both with only 2 bytes. But this doesn work with other data with more than 2 bytes like:
Ch1 Watt-Second Abs Counter where Byte 6 = LSB and Byte 10 = MSB. Help me please. See my test3.jpg
Message 7 of 9
(4,961 Views)
You can't just ignore the other bytes and you can't convert 5 bytes to U16 (two bytes) or U32 (four bytes). You can use multiple joins, you know.
Message 8 of 9
(4,948 Views)
I'm trying to do what you said but it have not been successful...i was wondering if you can make a little diagram please
Message 9 of 9
(4,932 Views)
