edit combo box array
Hello Mike,
I gave you an example with 3 parameters but there are tests with 5 parameter or 6 or 7 its unlimited, i need it to be flexible.
I cant say i have 5 parameters and thats it...
Message 11 of 31
(2,130 Views)
Hi Alvarion_…,
ok, then you can use a table with the current selected values and if a user select a new cell you can move your combobox to this place and write the new values into the drop down menu. Now the user see only the allowed values and can select them. If he click into another cell, move the combo box and change the values.
Hope it helps.
Mike
Message 12 of 31
(2,128 Views)
Hey,
Thanks, it sounds great ill try that.....
Message 13 of 31
(2,123 Views)
Last qst....how can i creat a table with combo boxes? i can create only arrays
Message 14 of 31
(2,117 Views)
Hi Alvarion_…,
you can´t create a table with combo boxes. What i meant is, you create a table and a single combobox. Depending on the selected cell in your table you move your single combo box to this position and change the item values.
Mike
Message 15 of 31
(2,114 Views)
Hello Again,
I jate when pepole ask me this but i will do it anyway, can you do a small example ?
Message 16 of 31
(2,113 Views)
Hi Alvarion_…,
see the attached example. Hope it helps.
Mike
Message 17 of 31
(2,099 Views)
Very Helpful, Thanks a lot!
Message 18 of 31
(2,096 Views)
Mike,
How/Where did you get the property "Old Edit Position" for the table? Smiley Surprised
I m unable to locate it in 8.5...
Can you show me the light?
- Partha ( CLD until Oct 2027 🙂 )
Message 19 of 31
(2,074 Views)
Hi Partha,
the example is in LabView 7.1. Smiley Happy In 8.5 "edit position" or "Editierposition" do the same.
Hope it helps.
Mike
Message 20 of 31
(2,065 Views)
