empty line
I have a 2d array (string) that has alot of empty lines, how can i delete the empty lines?
i have tried doing as you can see in the attached  vi but its takeing alot of time and if i will try to use the "empty array?" comp he will not see the empty strings as empty array.
can it be done better?
Message 1 of 16
(5,407 Views)
Can you sort them first?  Sort then find first empty element then you can delete the rest.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 2 of 16
(5,406 Views)
Regular sort can work only with 1D arrays
Message 3 of 16
(5,404 Views)
I use a 2D sort I fond on NI's site.  Here is a few:
http://zone.ni.com/devzone/cda/epd/p/id/4077
http://zone.ni.com/devzone/cda/epd/p/id/2502
Matthew Fitzsimons
Message 4 of 16
(5,400 Views)
1st of all thanks for the sort i know i will need it but it doesnt help me its still slow 3000 lines will take it alot of time
Message 5 of 16
(5,395 Views)
Post what you want sorted.  Should be fast.
Matthew Fitzsimons
Message 6 of 16
(5,393 Views)
ok, this it it....its more then 3000 Smiley Happy
Message 7 of 16
(5,391 Views)
You need to set the data as defult (Edit -> Make current Value Default) before saving the VI.  You posted an empty array.
Matthew Fitzsimons
Message 8 of 16
(5,388 Views)
The data you posted is empty.  You forgot to save the value as default.
Message 9 of 16
(5,387 Views)
Message 10 of 16
(5,383 Views)
