encoder conversion
I have this encoder factor and I'm trying to figure out how to convert it to real world units for Velocity and Acceleration.
1.0 mm / 34,304 counts
How do I get the following :
1.0 mm/s (velocity) = ????
1.0 mm/s^2 (acceleration) = ????
thanks
(4,216 Views)
You can do it based on frequency.
Or you can just get the counts once a second.  From there, it is really simple math: counts/34304
(4,205 Views)
Accepted by altran
To calculate velocity, first capture some number of points. As Tim pointed out distance is counts/34304.
Velocity is that value (distance) divided by the time it took to collect the counts.
Acceleration is the differences in velocity between consecutive data points divided by the difference in time between the two data points. dV/dT
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,185 Views)
