enet 9163 and ni 9211 thermocouple module
2 VIs are running on the same desktop trying to acquire one on-demand sample per minute (1/min. for each VI).
The second loop that is started returns every time the error -50103:"the specified ressource isreserved. The operation as it is defined couldn't finish properly" (translation from the French version).
I am starting and stopping a task correctly with acquisition of 2 samples (1 for the CJC and the other for the type B thermocouple)
Could someone help ?
Thanks.
(2,466 Views)
Accepted by topic author Franck5978
I found my error, I had to configure continuous sampling with DAQmx Timing (instead of finite samples) and insert a difference of phase between my 2 loops.
Bye!!! :smileywink:
(2,454 Views)
