enum help
can someone please explain to me what enum and rings are? links will be helpful too thanks!
(2,821 Views)
Accepted by topic author j49sun
Read the LabVIEW Help. https://www.ni.com/docs/en-US/bundle/labview/page/front-panel-controls-and-indicators.html
Both provide a list of values, but enums are their own datatype whereas rings are integers. Enums are not usually used on the front panel of top-level user interface VIs since they don't look like "natural" dropdown controls. It's not unusual to find enums as front panel controls of subVIs especially if you want to provide a restricted set of values. Enums are self-documenting - if you connect an enum to a case structure then the case elements will have the same names as the enumerations.
(2,809 Views)
thanks!!
(2,797 Views)
