purpose of Merge Errors function ?
I am looking at an example VI for a NI-HSDIO card. In this example, there is a Merge Errors. What is the purpose of using a Merge Errors function? Synchronization?
(6,002 Views)
Accepted by topic author nyc_(is_out_of_here)
I can't say how they're use in the NI-HSDIO example, but yes, the merge errors function is often used for basic synchronization of parallel tasks.  Take a look at the image I attached.  Here the Merge Errors function is used to make sure that none of the DAQmx Start Task VI's executes unless and until all of the DAQmx Create Channel VI's complete successfully.  Note that this screenshot is from 8.6, so the merge errors function might look a bit different.
Mark Moss
Electrical Validation Engineer
GHSP
(5,992 Views)
The example VI that I found in C:\Program Files\National Instruments\LabVIEW 2010\examples\instr\niHSDIO  directory is doing two parallel tasks of acquisition and generation.
(5,971 Views)
