enum to string
how to conver the enumerated to string?
Balaji DP
Message 1 of 34
(35,159 Views)
Hi balaji_dp,
create a property node of your enum control. Select "Strings[]", use the index array function. Connect the array from the property node and as index the value from the enum control.
Mike
Message 2 of 34
(35,153 Views)
Use the enum prooperty node "strings[]".
Software developer
www.mcm-electronics.com
PORTUGAL
Message 3 of 34
(35,151 Views)
Mike and Jorge,
Try "format into string".
I think you'll like it. Smiley Wink
Ben
Message Edited by Ben on 07-10-2008 08:37 AM
Message 4 of 34
(35,150 Views)
Hi Ben,
thank you, now where you say it, i remember. Smiley Happy
Mike
Message 5 of 34
(35,146 Views)
in my enumerated control   strings  and values are like   a-23, b-44, c-56....
then how could possible to do with property node and index value......?
Balaji DP
Message 6 of 34
(35,130 Views)
can you send example? for format into string....
i tried this but i didnt get....
Balaji DP
Message 7 of 34
(35,125 Views)
Thanks for the information.
But do you think that it's better to use your way instead of our (performance/memory)? Cause, I prefer to use one property node instead of using one enum local variable connected to "format into string"
Software developer
PORTUGAL
Message 8 of 34
(35,118 Views)
Accepted by Chris_Cilino
The top is using the Format Into String and the bottom uses the property node and an index array.
http://www.ni.com/academic/lv_training/how_learn_lv.htm
Message Edited by Dennis Knutson on 07-10-2008 08:07 AM
Message 9 of 34
(35,119 Views)
Hi balaji_dp,
try this. Smiley Happy
Mike
Message 10 of 34
(35,114 Views)
