enum to string
Hi folks,
How to convert Radio button enums to String ?
Because there is no string[] property node and ring text as well.
Thanks in advance!!!
With regards,
Shree
Message 31 of 34
(2,680 Views)
Format Into String works for me.
Message 32 of 34
(2,674 Views)
If you're talking about a single value, the Format Into String function works.
If you want to get all of the Labels of the Radio Selections, you can loop through the Controls[] property and grab the Label.Text for each control.
Message 33 of 34
(2,672 Views)
There's also an OpenG function called Get Strings From Enum, under the LabVIEW data palette, which will return the string value of an enum, and all possible values as an array of string.  This works without references, and works on RT.
Message 34 of 34
(2,635 Views)
