enum with multiple choice
I want to select from a enum of 6 items 3 items.
This moment I can only choose 1 item. What is wrong?
The guideline says it is possible, but how?
Rusja
(5,159 Views)
Which guideline? An enum is a datatype. Fundamentally it's an integer value, not an array. Therefore it can only have one value. Are you thinking of a ListBox?
(5,154 Views)
It is a german guideline. Labview fundamentals 8.0.
There is written :
Enum controls can produce Pulldown menues for multiple choice.
But I think listbox possibility is the one I will use.
Rusja
(5,138 Views)
Ah, it's an issue of semantics. When they say "multiple choice" they don't mean that you can select more than one. They mean you can select "one" from "many choices". Kind of like multiple choice test where you have to select one of the answers.
(5,136 Views)
Accepted by rusja
it is a good explanation.
I tried to give you a KUDO but I failed.
I think you answered my last question a week ago, there I gave you a solution point and a Kudo but now I failed.
I use the Opera browser now perhaps this is a problem?
 Greetings
Rusja
(5,126 Views)
Don't worry about the Kudos. As long as you've got your question answered, that's what counts.
Don't know if it's a problem with Opera.  I'll mention it on the Kudos thread.
(5,106 Views)
