error 1 occured at property node(arg 1) in VISA configure serial port (instr).vi->receiver.vi
error 1 occured at property node (arg 1) in VISA configure serial port (instr).vi->receiver.vi
Message 1 of 18
(10,338 Views)
The same question recently appeared in the Instrument Control Board.
Lynn
Message 2 of 18
(10,329 Views)
Ok, but what does the code look like that generates this error? What version of LV? What OS? Can you try a different port? Is this a builtin port or a USB dongle?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 18
(10,309 Views)
lab view version : 13.0 (32 bits)
os : windows 8.1
dial up model but we connecting through usb port.
Message 4 of 18
(10,296 Views)
What does the code look like? Who makes the USB dongle that you are using?
Mike...
LabVIEW Champion
Message 5 of 18
(10,284 Views)
we using a dial up modem description is :
RCV336ACF/SP
R6750-21
ROCWELL 96
9748 B49756-7
MEXICO..
we connect through RS-232 via usb dongle
n m attaching the code error
Message 6 of 18
(10,268 Views)
If the VISA resource name is Empty then you will get this type of error. You might have left the error out wire open thats why you are getting the pop-up message. Check whether you can select the VISA resource name and try.
Message 7 of 18
(10,263 Views)
RCV336ACF/SP
R6750-21
ROCWELL 96
9748 B49756-7
MEXICO..
The information you sent is noted -- but it is also not what I needed to know.
If you want help, answer the questions I asked before and stop resending the same bitsof info over and over again. If you can't show us your code, or tell us who makes the RS232 dongle you are using, don't bother replying. It's wasting our time.
Mike...
LabVIEW Champion
Message 8 of 18
(10,251 Views)
hi team,
i agree with P@Anand.. ISA resource name is Empty and its giving me this error. Question is why is it empty and what to do to make it show COM ports as mine is not showing COM ports even when device manager shows it.
Regards
ALi
Message 9 of 18
(10,031 Views)
The error indicates that you have not installed NI-VISA.
Message 10 of 18
(10,018 Views)
