error 1 occured at property node(arg 1) in VISA configure serial port (instr).vi->receiver.vi
I installed VISA drivers from http://sine.ni.com/psp/app/doc/p/id/psp-411 and now its giving the following error:
Error 1 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->serial_t.vi
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Regards
ALI IJAZ
Message 11 of 18
(2,372 Views)
What, if anything, do you have for the VISA Resource Name? Did you click on the pull-down menu and select an available com port?
Message 12 of 18
(2,354 Views)
Drop down list doesn't show anything. It shows  "Refresh" as shown in screenshot attached.
Regards
ALi
Message 13 of 18
(2,329 Views)
That means that there are no serial ports detected by VISA. What does the device manager say and is there anything at all listed on MAX? Are you using a USB-RS232 adapter?
Message 14 of 18
(2,326 Views)
Im using RS 232-485 USB converter
Device manager shows com port 2
Message 15 of 18
(2,316 Views)
And nothing shows in MAX? Unless it's shown on MAX, you won't be able to use it. Not all converters play well with VISA. Do you know the chipset that the converter uses?
Message 16 of 18
(2,304 Views)
I'm not sure what could be wrong. I've never had a problem with ftdi based converters.
Message 18 of 18
(2,288 Views)
