error 10001
I had this error before. I set up the virtual channel config. And this error is gone. But, now, I have it again. And even I set up the config, it is still there. I don't know what is wrong.
(3,653 Views)
Are you usning traditional DAQ. We used to see this before we switched over to DAQmx. It has to do the with the order of the channel array that you are give to the read. When you initilaize the arrray and then read it it has to be in the same order. Thats what I think I remember.
Tim
GHSP
(3,641 Views)
Hi Tim
My system is as below:
CVI Runtime 6.0.4
IVI Engine    1.6
LabView 6.0
LabView Runtime 6.0
LabView Runtime 7.0
LabView Runtime 9.0.1
Measurement and Automation Explorer 4.7.1
Traditional NI-DAQ 6.9.3
The only difference between my old system and new one is the Measurement and Automation Explorer. The old one has a version 4.0.0.3010
(3,637 Views)
Hi Robin.
OK it's been a while since LV6.i.  Which function is reporting your error?
(3,631 Views)
Hey Robin,
Please post in only one thread.  Other thread here.
Jake G.
(3,616 Views)
