error -10401 with pcie 6321
I have the -10401 error when I want to configure a port in 6321 PCIe card (3 ports of 8 bits each).
I use the sub-vi "DIO-configure a port."
I checked all the settings.
I also tested the sub-vi "Read a digital line" and i have the same error.
The PC which used for my tests is on Windows XP and using LabVIEW 2010 SP1 and NI DAQ  MX 9.3.5 (supplied with the PCIe 6321).
Sincerely,
(3,032 Views)
Accepted by ErwannLM
That function is part of the obsolete traditional DAQ driver. Use the DAQmx functions on your palette.
(3,026 Views)
Thank-you for the quick response but it's not possible to use the traditional DAQ driver instead?
I have to resume some vi's from an old project without modify them.
(3,022 Views)
No, it's not possible with that newer DAQ card. If you wanted compatability with the old code, you should have gotten the same board that it used.
(3,016 Views)
ok. thanks for yours explanations.
(3,009 Views)
