error--1073807246
Hi
iam using Fieldpoint 1000 iwant read module name Programmatically by using (!B) ReadallmoduleIDs (VISA).vi but give me this error -1073807246 the resource is valid,but VISA cannot currently access it. way give me this error and what the solution this error.
use
  FP-1000
  module AI-100
               AI-110
               TC-120
(9,016 Views)
hi Spring,
Have you looked at the info in in the KnowledgeBase?  See here.
Is it describing something similar?
RayR
(9,007 Views)
Hello Spring,
I'm going to guess that the first time you ran this VI that you did not receive this error - basically, this error means that something is already using your FP resource.
Good luck!
Janell R | Applications Engineer
(8,990 Views)
Hi Janell,
Good catch.  We're saying the same thing, but your description is much easier to follow. 🙂
It appears that somewhere in the code, the session was left open.
RayR
(8,970 Views)
