wire connection types
I am a learner in LV , and i am facing this problem,
you have connected to terminals of different types. the type of the source is long 32-bit integer. the type of sink is void. and it is also vice-versa.
thanks for helping me.
(3,206 Views)
What are you wiring to?  Is it a terminal / indicator (unlikely), or a sub-vi? or a Call Library Function (dll)?
(3,202 Views)
it is in the sub-vi of a DLL ,
and the connection is bet contol to method of invoke node and from method to indicator
(3,197 Views)
Hi gnag,
That is what I suspected..  It looks like the control is wired to the wrong input parameter, or the appropriate parameter is missing, or it is of the wrong type. Or something else since I don't have enough info at this time.
Are you implemeting a VI from an API (dll from 3rd party)?
Can you describe what you are doing and what the dll does.  This will shed more light on the matter.
(3,180 Views)
