04-14-2011 05:54 AM
I had a working VI that could balance a wheatstone half bridge and read and record measurements. My sensors are attached to a SCXI-1314 modle in a 1520 box in channel 0 (positioned as in the manual for half bridge) with the completion resistors in the appt places in ch7. It used 'custom voltage with excitation'.
Wanted to improve this VI so that it would also do a shunt calibration. I therefore connected the shunt resistor in the board over my active sensor as in the manual. I tried then to create a virtual channel for it - but it wouldn't work. So I gave up on that idea and tried to put things back how they were - deleted the virtual channel, and removed the connections to the shunt resistor. Except now none of my previously working VIs will work. I have built a new VI, and that can find a signal but not balance the bridge. I get:
error 200380 occurred at DAQmx perform bridge offset nulling operation.
I have checked the hardware again, and it's all wired correctly - it seems like the VI can see the channel but doesn't know what to do with it. Have running the VIs with and without a custom voltage with excitation channel created but nothing works.
Help!
04-18-2011
08:00 AM
- last edited on
12-15-2025
02:00 PM
by
Content Cleaner
Hi LucyWH
Have you tried re identifying the chassis in Measurement and automation explorer?
Have you changed the jumpers at all as when rewiring this is easily overlooked?
I have found some links that you may find useful:
http://digital.ni.com/public.nsf/allkb/6E94108C9611910186256D43007C2584?OpenDocument
http://digital.ni.com/public.nsf/allkb/8A0E097385A4269586256DBA0054E668?OpenDocument
