error -2146959355 server execution failed on ActiveX Invoke Node?
I wrote a VI to reload all the module prototypes of the steps in a TestStand sequence (note: all code modules are LabView VI's).  Whenever it gets to the LabViewModule.LoadPrototype call, I get a "server execution failed" error (error code -2146959355).
I've tried solutions 1-3 in the following document to no avail:
Why Do I Get Error -2146959355 When Using ActiveX or the Report Generation Toolkit?
http://digital.ni.com/public.nsf/allkb/1c025f018cb5761686256c56007dd258
Any ideas as to what else I can do?
(Incidentally, if anyone has a clue as to what reference is causing a "References to PropertyObjects were not released properly" warning dialog... please do say).
Melissa
(double-posted this to the TestStand forum in case different people read the 2 boards...)
Message 1 of 1
(2,725 Views)
