error -2147467259 and -2147217865
Hi All,
Previously i've been passing data and inserting it in database using the method which is working.
In the attached vi, it is basically the same method of inserting data.
However, 2 error occured while its running, which are -2147467259 and -2147217865.
I've attached the error message too.
please advise. :smileysad:
 rgds,
Roziela
(3,975 Views)
Search the forum with that error codes. you will get a couple of threads discussing about them. Post if issue is still there.
(3,962 Views)
Accepted by Aleizor
Hi there
The error message states that the datasource name (i.e. the name of the ODBC connection) can't be found. Check the name of your DSN in your ODBC settings.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,961 Views)
Thanx Chris~
it is the name of the ODBC connection..:smileywink:
rgds,
Roziela
(3,924 Views)
