error 2147467259-maximum extents reached??
While using the db tools during a DAQ operation, I am experiencing the above error saying maximum number of extents reached. Is it a database problem??, Its occuring only for some tables and how can I knock it off?? The Labview program is reading the data and writing to oracle database.
Any comments please?? Please find the enclosure of the error image.
I am using labview8.5version
Thanking you.
(3,228 Views)
If you look at the following KB and do a search for your error it explains the cause:
Also this link may be of help:
Hope this helps,
(3,210 Views)
Thanks Rob.
(3,189 Views)
