error 33180
Hi
 iam using this vi in file attachment to change range in AI-110 Module in FP-1000 the VI change only channel 0 and channel 1 but other channels give me this error 33180(FP_Error_Data_Size_Mismatch: The amount of data provided does not match the number of data items required or the number of channels to be addressed) Please send me the solution
thanks for all
(3,160 Views)
Hi Spring,
I would recommend taking a look this [broken link removed; article no longer available] KnowledgeBase Article which describes how to programmatically change the range of a FieldPoint Analog Input Module.  The method described in this document is the recommended method for changing the range of your AI-110 module through LabVIEW.
Please take a look at this document, and let me know if you have any questions.  Best of luck on your application, and have a great day!!
Ching P.
DAQ and Academic Hardware R&D
(3,149 Views)
