error 6
Dear all,
I tried to compile a project (vi) and I got the following error msg:
Error 6 occurred at Delete in AB_Engine_Delete_Internal_Files.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_CreateNewWizard_Invoke_CORE.vi->EBUIP_CreateNewWizard_Invoke.vi->EBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic file I/O error.
NI-488: I/O operation aborted.
Any suggestion?
Thank you very much,
Davide
(3,778 Views)
Is it the second time you're building the application?
Do you have any files/folders open from the previously built application?
One of the things the application builder does is delete the previously compiled application files.
If any of the files/folders are open, it may not be able to delete them and will produce an error.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(3,761 Views)
I think you got it right, thanks. And now I don't get the error, even though I didn't exactly know how to fix the issue.
(3,676 Views)
