don't know name of function???
Hi all,
can someone tell me what function is the one highlighted with the blue rectangle in the screenshot i attached??
Thank's
pollon
(3,408 Views)
That's a local variable. You can right-click for example a control and choose Create and then Local Variable.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,401 Views)
Thanks for your help Even. Could you also tell me what is the house simbol in the local variable ??
pollon
(3,382 Views)
Accepted by topic author pollon
The house symbol means that it's a local variable (someone correct me if wrong). If it's a global variable you'll see a symbol of "planet earth".
Even
Topro AS
Norway
(3,376 Views)
thank you very much.
Bye bye
pollon
(3,357 Views)
