don't know name of function???
Hi all,
can someone tell me what function is the one highlighted with the blue rectangle in the screenshot i attached??
Thank's
pollon
(3,406 Views)
That's a local variable. You can right-click for example a control and choose Create and then Local Variable.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,399 Views)
Thanks for your help Even. Could you also tell me what is the house simbol in the local variable ??
pollon
(3,380 Views)
Accepted by pollon
The house symbol means that it's a local variable (someone correct me if wrong). If it's a global variable you'll see a symbol of "planet earth".
Even
Topro AS
Norway
(3,374 Views)
thank you very much.
Bye bye
pollon
(3,355 Views)
