error 7: while running EXE
I am getting below error while running exe. But while running in development environment it is working fine. Please help
Open VI Reference in PRJA2871_Firmware_LoadVI.vi:70002->PRJA2871_Firmware_Parameter Download.vi->PRJA2871_MCRL Main Screen.vi<APPEND>
VI Path: <b>C:\LabVIEW Code\Code New V2.1 test\EXE\MCRL_VCR\MCRL VCR.exe\Ethernet\PRJA2871_Download_Ethernet.vi</b>
Built Application or Shared Library (DLL): Make sure all dynamically loaded VIs were properly included in the build specification for the application or shared library.
LabVIEW Real-Time: VIs built into executables cannot be accessed through VI Server calls. Use Source Distributions to dynamically call VIs on Real-Time targets.
(3,579 Views)
You probably have a filepath that is incorrect when running as an executable or a file that you need to include with the executable.
There's nothing else we can help you with unless you share the code.
Cheers
(3,563 Views)
Accepted by pmg08
Hi James,
Actually it was my mistake. I was using one VI for debugging purpose. But that VI was not inside the project. Hence it was throwing the error
(3,556 Views)
