error 8 occurs in excel sheet write
We need some help in programming Labview 7.1 urgent!!!!!
I am sending you one error.jpg file….the example is - write data to excel sheet.
But suppose the excel sheet is opened already by some one then labview shows ERROR 8, ERROR 43….
And we can not resolved these errors…how can we prevent my application from pop up dialog Error 8….
so please give some idea about resolving these errors.
(2,896 Views)
Hi miloo
If you want the error dialog to stop popping up, you can create a case structure to handle the case when this error is caught. This is done by simply outputing nothing to the error message. This case is handled by the cancelled output of the file dialog.vi
Hope this helps
Van L
NI Applications Engineer
(2,869 Views)
continued here... Or here?
(2,779 Views)
