the table to be printed is wider than one page
hi,
  the Width of table to be printed is wider than one page. even i set the print direction is horizontal, it still more than the paper. and i need to print the whole table on a page. so, is there some method to solve this problem?
  best regards!
(3,263 Views)
Hi xyl,
one solution is to shrink your table. I don´t know how big your table is, but maybe it helps to shrink also the margins.
Hope it helps.
Mike
Message Edited by MikeS81 on 06-24-2008 09:08 AM
(3,262 Views)
thanks for your help. i can't shrink the table because the cell of table is already the smallest. i am thinking if there is some method to make one row into 2 rows or even more.  For example, the width of table is fixed, if the content is longer than the table, the longer part will automatically moved to the second row. Do you have some idear about this?
thanks
(3,242 Views)
Do you have the ability to configure the print, such as selecting Landscape for layout.  Or setting up the printer's default to landscape.  Or using Legal paper?
Is the table in Labview or did Labview fill the cells of another application, such as Excel?  If so, you could also select print > fit to page.
RayR
(3,240 Views)
can you explain how you print the table? Is this just a table indicator on the front panel?
In this case you can set the I/O to scale to the page. Look for the printing option in the VI properties.
(3,238 Views)
i'm really appreciate for all your helps. But i am so sorry that i failed again. The VI is just like this:
(3,218 Views)
Hi xyl,
this table is atleast 240 characters wide. Using "Arial, 10pt" I can fit ~130 chars on a landscape A4 sheet...
Solution: setup some scaling in your printer driver or use some 5pt font!
(3,216 Views)
