error code 1088
LabVIEW 7.0 WIN98 and WIN XP
Hello
To count the numbers of line of a multi line string i use the invoke node: "Get Nth Line° from the string, Under WIN98 the function works perfekt and now under WINXP i always get the error code 1088. After continuing the result itself is correct. How can i solfe the problem? Actualy i will not replace this subprogramm with another solution.
Thanks.
Markus Baumgartner MBW ENGINEERING
(3,716 Views)
Can you post the VI so that I can try to reproduce/understand exactly what is happening ?
Tryin' to help...
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,714 Views)
