fpga
I would like to generate a current waveform with a signal generator.
Is it possible to build a current generator with a FPGA? I mean a device which accepts a input voltage and give an output current?
If the answer is yes, which is the dynamic?
Thanks a lot
Gc Dago
(4,940 Views)
Dear GcDago,
with NI FPGA solutions you can use the cRIO-9265 module to generate up to 4 simultaneous current Outputs, 0-20 mA. Here  is the link to the module's catolog page.
This module can be used either with an Embedded cRIO solution (Controller + Active Backplane w/ FPGA) or with a PXI/PCI FPGA Board from the 78xx family using a cRIO passive backplane (which does not include an FPGA chip, already present on the PXI/PCI side).
Hope this information helps.
AlessioD NI Italy
(4,925 Views)
