error code 1124: vi made of labview 4.0.1 and has no block diagram
when i try to open the old vi in labview 7.0 i received the message " -" Labview load error code 11 Vi version 4.0.1 cannot be
converted to the current labview version 7.0 because it has no block diagram"
require help to open vi and to find out block diagram.
(2,667 Views)
A VI with no block diagram cannot be converted to a newer version. In essence, it's missing the source code and without that, LabVIEW cannot recompile. Once a block diagram is gone, it's gone forever. If the person who originally saved the VI without the diagram did not make a backup of the original or if the original cannot be found, there is nothing that anyone can do.
(2,667 Views)
