error code -50400
hi,
When I Run my host side VI for a program which DMA transfers.
It gives a error code as -50400. The error was expalined as could not transfer from Fpga.
Please guide me to fix this error.
Vedha
(7,745 Views)
You will have to proivide more info, like sample code or screenshots of the code. Maybe hardware used.
André (CLA, CLED)
(7,727 Views)
Hello Sir,
I want to generate the SSB and ISB from the AM Example code which is present in Ni form, I am Using LV 8.2 with 5640R card.
after compilation of my FPGA  Vi when I run my host Vi it shows the Error 50400, I am using two FIFO on host side , one FIFO is giving the right responce but not the other one, its showing the error. please guide me to solve the problem.
here i put a screen shot of that problem
(7,373 Views)
Hi did you ever fix this problem? What was the solution?
(7,041 Views)
-50400 error description.
The transfer did not complete within the timeout period or within the specified number of retries.
What happened: The node didn't receive all of the 1000 elements within the timeout specified (50000 ms), thus returning this error.
Possible solutions:
1. Make time out larger;
2. Reduce the number of requested elements;
3. Ask the number of available elements before reading the elements.
Hope this will be of help.
A lot of the time the solution can be derived from the error description, sometimes it can't. In this case you could have.
André (CLA, CLED)
(7,019 Views)
