run 2 vi simutaneously
can i run two vi. on a Lenovo laptop simultaneously? one NI 435x Thermalcouple.vi for temperature acquisition. the other vi for 6K Parker motors motion control (no data taking).
Labview version 7.1
Window XP
thanksSmiley Happy
Message Edited by Tian Zhou on 06-20-2008 01:53 PM
(3,475 Views)
You should be able to.
Are you having problems when you attempt doing so?
RayR
(3,463 Views)
Or, are you not sure how to run VIs in parallel?
Message Edited by smercurio_fc on 06-20-2008 05:05 PM
(3,447 Views)
there is no prolems at all.
i am concerned because i don't know if the other vi will mess up with the vi which is doing data ACQ.
it doesn't seem to be the case. thanks
(3,431 Views)
Do they share similar (same) resources?  If not, then it should be okay.
If they do, then you could use semaphore(s).
RayR
(3,429 Views)
