error codes
hi nicolas,
can you identify at which point your VI fails?
Regards
Ray
Regards
Ray Farmer
Message 11 of 14
(1,004 Views)
thanks for your interest.
I am going to be as clear as possible.
I have designed today a new VI which works in a better manner than the previous one:
In input, I have a DC voltage.
I specify the number of samples I want to work on. Then I compute an average of them, and save this average into a file.
With this new VI, I have the same kind of problem than with the previous one: how to specify the sample frequency?
Here, I say: "I want 40 samples" but I don't know at all which frequency the card uses to acquire them. I would like to be able to say "I want 40 samples, with 10 seconds between each one"
That's a problem for me, because as I will
have to manage 4 sensors, I need to avoid wasting the use of the processor.
Thanks again and I hope I am clear enough.
Nicolas
Message 12 of 14
(1,004 Views)
All you need is to insert a delay of 10sec into you for loop.
Regards
Ray
Regards
Ray Farmer
Message 13 of 14
(1,004 Views)
thank you for your support!
you have an Adlink card? I have found no vi with some Adlink libraries on the net.
Nicolas
Message 14 of 14
(1,004 Views)
