error executing application after create installer
When I execute my main vi, launcher.vi I receive an error when from it I call another vi called main.vi. I attach here the error.
Could anyone help me please?
Thanks in advance,
ToNi.
(3,114 Views)
Hi ToNi.
  The problem might be related to windows properties of the VI you are trying to launch. Check this link
http://digital.ni.com/public.nsf/websearch/E1B8CA0B546A803486256A33005AF221?OpenDocument
Hope it helps
Javier Gutiérrez
NI Application Engineering
(3,098 Views)
Hello Javier,
Thanks for your help, I saw the article about it, and it is good but the problem persist. In my vi properties I had checked Auto-center option that is not compatible in run time, then, I unchecked it but it still no work. What is the problem? Is possible that the problem is that when I run the vi (main.vi) from (launcher.vi) I use an Import VI Strings Invoke method (I attach here the block diagram and the vi properties of main.vi)?
Thanks in advance,
ToNi.
(3,093 Views)
Hi again,
The problem is the Import VI Strings Invoke method.... when running my standalone application (in development environment it works) but... I need to use Import VI Strings Invoke method when muy standalone application is running in order to change language of my application. How could I do this?
ToNi.
(3,090 Views)
