error filename measurement file
Hi.
In my project, I have used the Read Measurement File function to read .tdms file. When I run the program on another folder or another PC, then select Open file name an error occurred, error window appears. Although it did not do wrong program operation but It is very uncomfortable. So I hope how could this error window does not appear?
(3,271 Views)
Hi ducta,
 Please copy all the files to a new folder or a new drive on a whole and try to read from that.
SrikrishnaNF
Srikrishna
(3,265 Views)
It is reported "Location is not available". I understand that it can not find the old location. But when transferred to another computer, you probably do not have the location as established. I want to know how it was not error Location is not available anymore. I need the how to config file functions Measurement Read?
(3,229 Views)
Can you post your actual VI.  It is really impossible to debug code with an Express VI without the actual VI.
(3,215 Views)
I deleted all the Start Path and Filename. Now only the first Browser to open filename new error window appeared and notice that "Location is not available" - Access is denied. Then open filename next time isn't fail again. Error only appear once - the first read.
(3,204 Views)
Accepted by ducta9
Your default path is "C:\Documents and Settings\user\Desktop\Save file\test.lvm".  If you are on a Windows 7 machine, that folder does not exist.  It is now "C:\Users\user\Desktop\Save file\test.lvm" (assuming you want this file on the desktop).  Since the search starts in the folder of the current path value, you get the error.  Change your default path to something that is valid.
(3,197 Views)
Thank
I was understand and have removed the old default filename. PMy program have worked correctly.
Thanks for your help again.
(3,190 Views)
