error in file logging
I have problem in logging data into a file.
File error says that the file is not valid, but there is a valid path and file.
Please help.
Message 1 of 8
(5,152 Views)
Show us your code, it is hard to find what is the cause without seeing the block diagram
Message 2 of 8
(5,148 Views)
Here is my code.
Message 3 of 8
(5,145 Views)
What part of your code is throwing the error?
Message 4 of 8
(5,141 Views)
I figured it out
Message 5 of 8
(5,133 Views)
Care to explain what was happening so that other people can learn from your experience?
Message 6 of 8
(5,129 Views)
Its not logging again!
This time no error but not logging.
Message 7 of 8
(5,120 Views)
You could be logging only on the first 4 iterations of your loop.  Was the intent to log every 4 samples?  If so, then you need to use the Remainder, not the Quotient, of the Quotient & Remainder function.
Message 8 of 8
(5,115 Views)
