questions about shift register
hello!When I use the shift register,A problem occur!what I want to use is the serial in shift register function,But found only use parallel shift register,someone can give me any suggestions?(The best way has an example of a serial shift register),thanks!!!
Message 1 of 20
(4,726 Views)
Sorry, I have no idea what a "parallel" or "serial" shift register is.  Could you elaborate on what it is you are trying to do?
Thanks!  🙂
Bill
CLD
(Mid-Level minion.)
Message 2 of 20
(4,718 Views)
Are you talking about extending the length or "history" of the shift register? You can drag the node down to expose a shift register buffer for more than one element.
Message 3 of 20
(4,710 Views)
thank your reply! what my meaning is just like I have an array of input of the shift register 1,2,3,4,5,6,7;In the calculation process, I would like to achieve in a row :after 1 finish  the calculation ,2 begins,later 3,4,5,6,7,this is Serial;but in labview is Direct the entire array operation,this is
Parallel,can you help ?thanks!
Message 4 of 20
(4,685 Views)
Accepted by topic author gthydrtyed
Are you using the shift register in while loop? Try using it in for loop, I believe you are looking for "Auto indexing" operation.
If I didn't understand your problem correctly, please attach the code you have developed.
Message 5 of 20
(4,675 Views)
I want to achieve :Each element of the array in the shift register Compare with 5,If less than 5, the output is 1, otherwise 0;but as you can see the vi is wrong ;Error reason is because of the shift register only for computing the entire array but not Single element,any suggestion?
Message 6 of 20
(4,666 Views)
better to use for loop with auto indexing enabled ( by default ) for input array.
you will get array values one by one.
then compare it with desired value and you can use bollean to 0,1 to get the out array of 0 and 1s.
Message 7 of 20
(4,658 Views)
thank you!!
Message 8 of 20
(4,648 Views)
thank you!
Message 9 of 20
(4,646 Views)
thank you!
Message 10 of 20
(4,644 Views)
