error messae
Here is the error message. I can not understand, what it means
messgae is giving below
Error -1074396061 occurred at IMAQ OCR Read Text 4
Possible reason(s):
IMAQ Vision: The size of each dimension of the window must be greater than 2 and less than or equal to the size of the image in the corresponding dimension.
Plez help me outSmiley Sad
(3,370 Views)
Seems pretty clear to me, you set a region of interest either too small or too large.  It needs to be greater than 2 in every direction, but less than the size of the image to be OCR'ed.
(3,335 Views)
