error "Wire: is a member of a cycle
Bill,
I dont think you understood what I was trying to say. I would be grateful to u if you read my query and then reply. I am having error due to the direct feed through behavior exibited by the transfer function, it doesnt make any change how many times I rewire the system.
Message 11 of 16
(1,499 Views)
thank you ben 62... I think it worked 🙂 Thanks a lot dude...
Message 12 of 16
(1,496 Views)
thanks to all who tried to help me.. 🙂
Message 13 of 16
(1,491 Views)
😞 I have a new problem  all the wires are closed now,but when I run the vi the control variables are going in some random function(nowhere near setpoint ). I know the controller and this configuration is working because i got a good response for the same in Matlab,but I want to do it in Lab VIEW. i have given a feedback node as BEn62 suggested and initialised it to zero. Any possible suggestions for this ?
Message 14 of 16
(1,488 Views)
0 may be too far from the setpoint for the system to converge. Try initializing the FB node with a value closer to the setpoint.
Ben64
Message 15 of 16
(1,468 Views)
@krishnapriyapg wrote:
Bill,
You're right.  I assumed you mistakenly wired something incorrectly, not that you actually believed it was wired correctly and that it was LabVIEW that had the issue.
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(1,462 Views)
