error writing txt to file
Hi!
I am trying to collect a number of touchpoints from a controller thorugh a SCB-68 and a Daqpad-6020E. There are about ten thousand touchpoints usually in three columns and for the first 1500 everything is okay and then suddenly a bunch random numbers start accompany the expected ones as can be seen in the attached txt file called ncrtg.log. Also, in the attached vi, I do not know how to end the while loop if a certain string comes up (closed) since the loop doesn't stop and I would need help with that. J1 and RTP is commands to the controller and with RTP the controller starts "sending" out the touchpoints.
Thank you
Navid
Message Edited by Navid on 06-27-2005 06:07 PM
Message Edited by Navid on 06-27-2005 06:08 PM
Message 1 of 9
(3,507 Views)
Ok, first things first. The file does not contain random characters. If you look at the numbers that are there carefully you see that the real problem is that you are losing characters in transmission. As a result you sometimes have two lines that appear concatenated, and data missing from other lines. How much data is the instrument supposed to return each time you send the RTP command?
Second, concerning the VI you posted, the code you have should stop when the input string is "Closed" (note the capitalized C). Also you never close the file reference for the datafile you are creating.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(3,489 Views)
The maximum amount of data should not be more than 200KB and that might be taken it to far but just to be on the safe side.
Thank You
Navid
Message 3 of 9
(3,475 Views)
Oh, by the way, the RTP command is only supposed to be sent once, I am not sure if that is the problem, tried to move the string constant with RTP to a sequence before but I am not sure if that is the correct thing to do to make it nly be sent once since it did not work.
Navid
Message 4 of 9
(3,463 Views)
Based on what I got last night, your code isn't correct. I'll play with it a bit and send you back a cleaned-up version tonight if that's OK?
Mike...
LabVIEW Champion
Message 5 of 9
(3,453 Views)
I appreciate all the help.
Thank You
Navid
Message 6 of 9
(3,448 Views)
Mike, you bring back some nice C.S. Lewis memories with that signature (although it's been a while since I read those, I think I should again). Thanks.
Welcome back to the exchange.
___________________
Try to take over the world!
Message 7 of 9
(3,442 Views)
Hi!
Managed to fix the problem, did not realize the fact that I was sending the RTP command all the time....
Thanks for the concern and effort
Navid
Message 8 of 9
(3,436 Views)
Glad to hear you got things going. I'm still sending along the version I cam up with...
Mike...
LabVIEW Champion
Message 9 of 9
(3,425 Views)
