error
hai
  whenever i try to open the detailed help from context help menu, im getting an error, which i attached with this post..pls help me out in this regard..
(3,488 Views)
Hi Sumithra,
This [link removed; article no longer available] link should help.
(3,458 Views)
hi voodoo..
 i still cant fix the problem.it shows that you have registerd successfully after following this
REGSVR32 "C:\Windows\System32\hhctrl.ocx"
REGSVR32 "C:\Windows\System32\itircl.dll"
REGSVR32 "C:\Windows\System32\itss.dll"
(3,430 Views)
Hi sumithra,
There in one more link.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,418 Views)
