errors-50350 and -89130
Yesterday I had a working PCI-4462. I could get data from it. Today I get errors-50350 and -89130 I powered down and rebooted many times. I have reinstalled 4462. MAX self test and reset both give -50350 Labview  8.2.1 and SignalExpress 2.0.0 give -89130 as soon as I ask for data. Where do i go from here?
Message 1 of 31
(4,872 Views)
Hi John,
 I recommend trying to determine if software (the driver installation) or hardware is causing the error.  Do you have another National Instruments card available to test in your PC?  Can you try installing your PCI-4462 in a different slot inside the computer?  Does a repair or reinstall of the driver fix the issue?  Do you have another computer that you can install the card into?  Do you see the same error on the second system? If the errors occur in only one PC, then I expect the problem is software or a problem with the PCI slot.  If the issue occurs in multiple computers, the PCI-4462 is likely the cause.
It is possible that a file has been corrupted with the DAQmx driver.  Hopefully a repair will fix the problem. If you cannot get the card to install and test without error on multiple systems, it is possible that your card has been damaged and will need repair.  If this is the case, please visit  ni.com/support to request support from an engineer.
Jennifer O.
Message 2 of 31
(4,836 Views)
Hi Jennifer,
I have had my PCI-4462 working in another computer.
I brought it back, deleted the drivers and did a repair.
I still get the same errors.
I am using 64 bit drivers here and 32 bit on the test computer.
Has there been a problem with 64 bit drivers under vista 64?
Do I need to delete Labview and max?
Message 3 of 31
(4,797 Views)
Hi John,
I have not heard of any issues.  I have a few things that I want to check.  Firstly, was this a clean install of the operating system or an upgrade from a previous operating system?  Do you have any other DAQ boards or DSA cards from National Instruments to test in the computer?  If not, do you have another PCI card to test to verify that your slot is working?
Try following the steps in this knowledge base to see if it helps: DAQmx Error Code -89130.
If you are still having difficulty let me know.  I do not think that you will need to delete MAX or LabVIEW, the first step is to see if any of the above suggestions will enable you to run your DSA board inside a test panel in MAX.
Jennifer O.
Message 4 of 31
(4,780 Views)
The computer came with XP 64 but would not load NI software.
The upgrade was a clean install. There is no upgrade path to Vista 64.
The system was working, I shut it down, the next morning the errors started.
The only time the board has worked is in my other computer. I know it will work here unless I have a hardware problem.
I will get a PCI video card to test with.
Message 5 of 31
(4,770 Views)
Hi John,
Testing with another PCI board will help us to test the PC's hardware.  Check in device manager verify that it shows that the card is installed  correctly (no conflicts).
 When you say that the only time the board has worked, do you mean the only time the board has worked since the errors started appearing or that it has never worked in your Vista 64 machine?  Also, what version of Vista 64 are you working with?  When you say that the computer would not load NI Software, what problems did you encounter and what process did you follow to be able to get NI Software installed?
Jennifer O.
Message 6 of 31
(4,759 Views)
I did not say that very well. The PCI-4462 worked for 1 week with Vista 64, after the errors started I did get the board to work in a 32 bit system.
I do not see any conflicts. Device manager thinks it is working.
I need to get a PCI board to do PCI socket testing.
Message 7 of 31
(4,760 Views)
A PCI video card works well in the PCI slot
There are no conflicts.
The driver is nidsarkw.sys File version 1.9.0f1
I still get the same errors with the PCI 4462 installed.
will not pass self test from MAX and signal Express aborts
I am running Vista 64 and am not familiar  with any install repair that may be available.
Where do I go from here?
Message 8 of 31
(4,704 Views)
Hi John,
The NI-4462 has been tested in Vista 64 without problem.  Do you have another Vista 64 machine available to you? or another DAQmx device (E-Series, M-Series, S-Series DAQ board) to test in your system?  Since the board works in the other PC, I believe your National Instruments hardware is good.  The issue may be the software install or perhaps the PC.
If you have another card, or Vista 64 computer we can specifically test that your driver install is good. Make sure that the driver you are using is NI-DAQmx 8.5.  It may be a good idea to try once again to uninstall the driver and install from the copy available on the web.  Download the driver and save to your hard drive and install from there.  You can locate the driver here.
Could you please comment on your results from running through the steps in the KB linked in my second post, and also answer my questions from previous posts?  It is difficult to continue troubleshooting with you without knowing your previous results.
Jennifer O.
Message 9 of 31
(4,682 Views)
Thanks Jennifer,
I will try to document my efforts better.
 Do you have another Vista 64 machine available to you?  NO or another DAQmx device (E-Series, M-Series, S-Series DAQ board) to test in your system? NO Since the board works in the other PC, I believe your National Instruments hardware is good.  The issue may be the software install or perhaps the PC.
If you have another card, or Vista 64 computer we can specifically test that your driver install is good. Make sure that the driver you are using is NI-DAQmx 8.5. Drivers less than 8.5 will not start to install on Vista 64. It may be a good idea to try once again to uninstall the driver and install from the copy available on the web.  Download the driver and save to your hard drive and install from there.  You can locate the driver here.  I uninstalled, downloaded and installed, I still get the same error in MAX.
The KB link was an uninstall, reinstall of the  ADC.  I had not done the  uninstall until today. I cannot tell any
difference. To make sure I got a good install I found the driver "nidsarkw.sys" and renamed it "nidsarkwjunk.sys" before I installed again. Do you have any open questions I have not answered?
John.
Message 10 of 31
(4,630 Views)
