eurotherm 3508 setpoint
Hello all
I am using the 3508  eurotherm controller and Serial comunication.
I want to send a program to the controller to then run it...
I can comunicate read and write parameters the problem is a scale in the setpoint, rate and dwell.
I found that the dwell decimal value as to be multipy by 60000 and that now works
The problem now is the setpoint/rate (that i found are the same, 10ºC is the same as 10ºC/min) temperature that does not make sence...
1º=3F800000h
10º=41200000h
100º=44C80000h
if you need more values i can post then but they are sence less unless someone know the equation.
Any help is apreciate thanks in advance
Tim
(3,624 Views)
Appears to be a continuation from here.
(3,605 Views)
Wouldn't this be in the manual?
(3,604 Views)
Sorry if it looks like a double post but here is to be discussed the problem of the 3508 equations
the problem is just that...
There are no communications handbook for the 3000 series.
So i have to guess values and find out the strage equation
Tim
(3,602 Views)
