event refnum
How do I make a'Cluster of Event Refnums for the input cluster of a bundle by name. I am trying to understand the function of an existing code, in the code he has used a cluster of event refnums as the imput for the bundle by name. Unfortunately, I can not even duplicate his code, because I can not figure out how he made the Event Refnum icons in the first place. I am new to LabVIEW and would appreciate any information you can provide. Thank you for your help,
(4,183 Views)
The Dialog and User Interface >> Events palette should have everything you need.
A User Event Refnum is generated and is specific to the datatype that it is registered with.
Cheers
(4,180 Views)
Accepted by Crumb
aputman
(4,172 Views)
Thank you, that is exactly was I was looking for, but did not no how to ask!
Luke
(4,133 Views)
