event structure with events caused by the program
Good morning everybody,
I am looking for a simple way to handle events caused not by the user, but by the program itself. Is there a possibility to use the event structures with the types of events I just tried to describe or will I have to use case structures inside a while loop?
I'd be glad to hear about other possible approaches, too.
Message 1 of 9
(3,758 Views)
Well... this is an easy answer, but what kind of events do you want to detect ? Depending on these events, the answer will be different.
You might also be interested by the example called "Dynamically register for events" (Helps >> Find Examples...)
Hope this helps 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 9
(3,751 Views)
Franzi,
as TiTou stated, you can have different types of events. From your description, i would think you are talking about programmatically generated events if you finished certain parts of your VI. TiTou already gave advice where to find good examples on this.
Another question i want to ask you is: Do you need the events to "trigger" some other part of code? If you answer YES, i would like you to take a look into your architecture. The reason for this advice is that you can often simply use synchronization-methods like queues or notifiers to solve this. "Examples" are included in LabVIEW within the template browser.
As an additional info: The types of events you can "catch" with the event-structure depends on the version of LabVIEW you are using. Example: with LV 8 you can catch some DAQmx-events.
Norbert B.
NI Germany
[Edit]: @ TiTou. i read your signature... have you already tested LV 8.20? i think it is very decent in comparison to 8.0 Smiley Wink
Message Edited by Norbert B on 08-31-2006 02:38 AM
Norbert
Expert: Geometry
Message 3 of 9
(3,747 Views)
Hi Norbert,
As I said yesterday is this post I only used LV 8.0.1 a couple of times for small things and haven't really done it in good conditions. I was bad tempered, under stress and instead of trying to get into the new LabVIEW style I just thought : "everything is different, that's just rubbish..."
This is, of course not the case, and I hope shortly I'll have time to really get into LV 8.20.
BTW, is there any improvement regarding the Shared Variable Engine since 8.0.1 ??
Epictetus
Antoine Chalons
Message 4 of 9
(3,740 Views)
My intention is to monitor a test stand. As soon as one of the analog inputs exceeds its allowed value (or one of the digital inputs gives the according signal) I want the hole test stand to stop. The solution that I came up with is to use a simple whle loop with Case structures inside. I was just wondering whether there is a simpler solution...
Message 5 of 9
(3,736 Views)
TiTou,
i can only link you to another thread where it is said, that few issues regarding the shared variable engine have been solved in 8.20.... so i do not know if it has effects on your applications or not....
Norbert B.
NI Germany
Norbert
Expert: Geometry
Message 6 of 9
(3,729 Views)
Franzi,
@franzi wrote:
[...]. I was just wondering whether there is a simpler solution...
Simple is the key here. What is simple? A solution you can implement within few hours without any knowledge of LabVIEW? A solution which takes you several days even with excellent knowledge of LabVIEW, but gives you the advantage that you can modify/extend it very fast without affecting the former functionality?
In my opinion, you should evaluate between a good architecture, which lets you enter modifications very smoothly, and a fast developementtime for the main issue. Regarding the main-architecture, you should definetly take a look into the templates since you propebly get new ideas on how to solve your issue Smiley Wink
Norbert B.
NI Germany
Norbert
Expert: Geometry
Message 7 of 9
(3,725 Views)
sory Franzi to monopolize your thread for another discution Smiley Sad...
Norbert,
Thanks for this link, I will definitly plan some new test of the shared variable engine in the coming weeks (or months), anyway by the end of the year I hope I'll develop more than 50% of my apps in LV 8.20 😉
Best regards.
Epictetus
Antoine Chalons
Message 8 of 9
(3,716 Views)
I got your point, Norbert Smiley Wink . My problem is that I always try to find the perfect solution, which sometimes makes me get lost in details. Well, I think I'll be fine with the links, which you and TiTou sent me.
Thank you both.
Message 9 of 9
(3,714 Views)
