example "NI 9870 Continuous Serial Read On-Demand Write.lvproj " doesn't work
I'm using NI-9870 and cRIO-9074 for serial communication with a outer module (Mesytec MRC-1).
I got the example "NI 9870 Continuous Serial Read On-Demand Write.lvproj " and managed run the programs.
I didn't change the example anywhere.
However, when I tried to write commands in order to read some status of MRC-1,
the response was the same as what I send.
This is strange.
For example, when I write "RE 0 0 4" to the module, I get "RE 0 0 4".
The correct response should  be "RE 0 0 4 0".
When I connected to the MRC-1 directly from a PC by PUTTY, I got the correct response "RE 0 0 4 0".
Could you help me and tell the reason why I can't get the correct response?
(2,867 Views)
Hello Tatsuya.F
This Muhammad Waqas from National Isntruments Japan.
I will be assisting you with you question.
1)How about the Baud rate you are using?
2)Can you please test by writing "RE 0 0 4 " with space after 4.
3)Are you sure you dont need to use EOL letter.
4) Please check for some other commands of RMC too.
Please confirm the above.
regards,
(2,853 Views)
Thanks for your advise.
I changed some program and made the length of time out longer, then it worked !
However, I have another problem.
When I send the command "re 0 0 4", the response on the "Port 2" is bellow,
re 0 0 4
RE 0 0 4 0
mrc-1>
(The number "0" on the last word at "RE 0 0 4 0" is the result which I need.)
Response on the Array 2 is bellow,(which is the same as the command I send.)
re 0 0 4
However, when I send the same command "re 0 0 4" many times,
message on the Array 2 suddenly change to " 0 4".
This change always happens after sending the same command 18 times.
Could someone help me, please ?
Tatsuya
(2,838 Views)
Tatsuya.F
It looks like that program being used is not reading the whole data available from the port.
Main reason can be , Read functions dont have enough time for execution.
I wonder what happen if you increase your time-wait function(from 10 mSec to somewhat 100m sec)
being used in your Host VI.
regards,
(2,823 Views)
