Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
examples for LabVIEW PDA module?
yqin
Member
12-06-2004
02:09 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I try to create a data file on my iPAQ using LabVIEW module. But I can not do that.
Is any example exsisted for LabVIEW PDA module?
My code is attached
0
Kudos
Message
1
of 4
(3,245 Views)
Reply
Re: examples for LabVIEW PDA module?
Rachana
Member
12-06-2004
04:44 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi!,
I can't find you code.
Could you re-attach it or explain a little bit more what exaclty are you trying to achieve?
Rachana
0
Kudos
Message
2
of 4
(3,234 Views)
Reply
yqin
Member
Author
12-07-2004
06:50 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I can not create / read / write a file .
How to attached VIs to this forum? I can not attach VI. I use the "browse" to find my VI and then submit post. It seems no file attached.
Test.vi 98 KB
0
Kudos
Message
3
of 4
(3,221 Views)
Reply
Philip_Courtois
Active Participant
12-21-2004
02:39 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Refer to this other thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=100128#M100128
- Philip Courtois, Thinkbot Solutions
0
Kudos
Message
4
of 4
(3,172 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
