examples using computers USB port
I need to create a labview 8.2 program that can look at the computer's USB port and transfer files from the USB stick onto the computers hard-drive. I don't know how to access and move the contents of the USB stick using Labview. Are there any examples I can download of this?
(3,627 Views)
Since USB keys usually show up as drive letters  (for example G:\) , wouldn't the standard copy move file VI's work by transferring from C:\ to G:\ or G:\ to C:\?
(3,616 Views)
Your right, it does. I've just finished proving that out. Only problem is I can't guarantee that the USB will always come up on the same driver letter? I think USB drive letters are not fixed but are rather assigned on an availability basis. But I don't think that problem will be insurmountable. That's where I'm at right now.
(3,612 Views)
I find that my USB key is pretty consistent in what drive letter it gets mapped to.  My regular key always seems to show up as G:\ at home. but as I:\ at work because there is a network drive mapped to G:\.  A different brand of key I just plugged in at home showed up as F:\.
I don't recall the last time a given key showed up as a different letter than usual, but I'm sure it has happened before.
I think your best bet may be to use a file path control that would let you browse to and select whatever drives show up on the system.
(3,607 Views)
There may be more upto date functions but ...
Check out the following post for a host of Windows related drive functions that should help nicely.
http://forums.ni.com/ni/board/message?board.id=170&message.id=9802&requireLogin=False
Specfically volume label and drive types.
(3,599 Views)
