programmically entering event structure
Hi-
I want to use an event stucture to calcuate some things when values on the front panel are changed.  It works well and as expected.
How do I force the calculation to occur when the vi is first run?  I've tried initally setting a value to try and force a change of value, but I can't seem to make it work.
Attached is a very simple example.
Randy
(3,071 Views)
Use the 'value signalling' property.
This will force the event to react as it would be on a 'value change'
Ton
My LabVIEW Ideas
(3,068 Views)
Value signalling is incompatible with the latching action of the boolean. To use TonP's suggestion you will need to go back to the standard switch action for the calculate button. If you want to emulate the latching action you could use a local variable to set the value back to false after it was read.
Lynn
(3,063 Views)
Ah, value signaling property.  I didn't know what that property was before, now I do.
Thanks.
(3,057 Views)
Lynn is right
Lynn
To my defense, I didn't open the code because I had the feeling Randy was looking for the Value signaling property.
Ton
On a side node, why a property and not a method?
My LabVIEW Ideas
(3,052 Views)
