excel chart width
does anyone know how to change the width of the graph?
i want to make the lines smaller or bigger.
(4,590 Views)
I am not able to open the code as I have only LabVIEW 2012. Which line do you mean. Regarding the Excel chart you have all the properties accessable through ActiveX, did you try that? Also you have some of the properties available in RG toolkit as well.
(4,573 Views)
Accepted by super_saiyans
I suppose you're talking about the line width.
Using ActiveX: Series --> Format --> ChartFormat --> Line --> LineFormat --> Weight.
Ben64
(4,545 Views)
Note that in the displayed graph the line width is probably not the issue. It is more likely the fact that you are using markers on data points that are very close to each other. To remove markers use Series --> MarkerStyle and select xlMarkerNone.
Ben64
(4,530 Views)
oh wow!!
thanks!
Thank you so much ben64
(4,512 Views)
up date. THANK YOU SOOOO MUCH!!
(4,468 Views)
